Dave_Thomson
Links in Context Sensitive Help to help files or html files
Status: Declined
  We're working on adding considerably more help and documantation to one of our commercial products written in LabVIEW.  It would be great to be able to link directly to specific topics in the help documentation from the context sensitive help window.  This is possible for VI help, but not for controls and indicators.  The same suggestion was made in the forums.  This would greatly facilitate help documentation, since the context sensitive help window mechanism requires very little programming and is already available.  Currently, one can add menu items or buttons that jump to any specific place in a help file, but that requires event cases for every instance.  Populating the context-sensitive help with relevant text and links could be done in a fairly automated way with some LV tools using VI Server.
DaveT
David Thomson Original Code Consulting
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Architect
Certified Embedded Systems Developer
There are 10 kinds of people: those who understand binary, and those who don't.
7 Comments
Darren
Proven Zealot
Status changed to: Declined
X.
Trusted Enthusiast
Trusted Enthusiast
What about if I gave it a kudo now, considering that I had never seen it before, or overlooked it?
AristosQueue (NI)
NI Employee (retired)
It would stay closed.
X.
Trusted Enthusiast
Trusted Enthusiast
Consider this a virtual kudo to the idea.
parthabe
Trusted Enthusiast
"What about if I gave it a kudo now, considering that I had never seen it before, or overlooked it?"
A declined idea cannot receive any kudos; ie, you cannot kudo a declined idea! 🙂
- Partha ( CLD until Oct 2027 🙂 )
X.
Trusted Enthusiast
Trusted Enthusiast
Which is why I gave it a vkudo.
The advantage of which is that you can give several of them to an idea:original-6.pngoriginal-6.pngoriginal-6.pngoriginal-6.pngoriginal-6.png
X.
Trusted Enthusiast
Trusted Enthusiast
As a matter of fact, here is my contribution to a revamping of the kudo system:
5 kudos: 5 kudos.png
10 kudos:
