| User | Kudos |
| 6 | |
| 2 | |
| 1 | |
| 1 | |
| 1 |
All service packs should be useable for the version you own, regardless of your SSP status. Currently, service packs are only good if you have a SSP active or had enough forethought to buy it in the middle of the year between versions.
