6 | |
6 | |
3 | |
2 | |
2 |
I'm often frustrated when after setting up nice background decorations I can no longer drag a selection box around items that are on top of it. I like to keep the decoration back there and sized correctly because it defines a functional area on my front panel where a set of related controls should fit (plus I like to work on a nice looking GUI). It would be great if there were an option to lock a decoration in place so it would not interfere with the subsequent selection of anything inside it. It is especially frustrating when trying to shift-click a large selection of small items since one missed click will de-select everything I was trying to select in favor of the background decoration forcing me to start all over again. I realize this is somewhat of a low priority request but if the implementation is simple it would be a very convenient feature.
