6 | |
6 | |
3 | |
2 | |
2 |
I have noticed that Property Nodes for certain numerics do not properly store Range Properties as the native datatype of the control, but rather stores them as DBLs. I have attached the screenshot to illustrate my point:
Notice the first Numeric's datatype is a DBL, and therefore you see no coercion dots for the Range Properties or the Value Property. The bottom two examples show I32 numerics, which have the proper datatype for the Value Property, but have the wrong DBL datatype for the Range Properties.
I propose that the Range Properties should reflect the datatype of the Numeric, just as the Value Property does!
(This may affect other Property/Invoke Nodes besides Range... please list any other datatype inconsistencies you may find in the comments.)
National Instruments will not be implementing this idea.
