| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 2 | |
| 2 |
There have been plenty of times where I'll be doing something inside a LabVIEW editor dialog (like the Properties dialog for a control), but want to quickly look at another block diagram or probe window. I can't, however, because the dialog I'm in is modal, meaning that it won't allow window focus to go anywhere else. So then I have to close the window, go find whatever it was I was looking for, and then re-open the window. Not a huge deal, but it bugs me everytime I do it.
Usually, this happens to me when I'm in a Properties dialog and need to look at a probe from the Probe Watch Window. I'd like to be able to switch to the probe I need without having to close the Properties dialog.
Therefore, I would like dialog windows (including the Icon Editor, which is also modal for some strange reason) to be non-modal. So that we don't forget about them, the windows could still be top-level so that they are always above all of our other windows.
