When you wand to exchange a VI with another VI (which you do very often when you put VIs of one class into a case structure - to program modular - and don´t want to wire all stuff again, like errorwires or instrhandle wires), you have go a long way through the context menue all the time. I would suggest to add the menue item "Replace with VI" on the top menue.
Example:
old menue path: Replace -> All Palettes -> Select a VI ...
NEW: "Replace with VI"
