Andreas_Pfichner
Make cluster area to click on bigger
Status: Declined
When you want to change cluster properties, you will have to right click on the frame of the cluster. For me it´s really a challenge to hit the right area to get into the right menue.
My suggestion is to make the area bigger, where you right click on...
Example:
right area hit:
wrong menue, which I hit more often than the right one:
3 Comments
oenk
I'm not really a big fan of that idea as I like the way the clusters look today.
But I can see your point...that happens to me a lot...
How about leting it the size it is right now but add a "Ctrl+RightClick" option to that when hovering over a free spot of the cluster to open the Cluster Menu?
Just thinking loud...
Andreas_Pfichner
Yes. Another, maybe better option would be to size up the cluster only temporarily when you move the mouse over it - and additionally: for me it would be ok to have that option only in the control editor, but then in the Frontpanel you keep the clusters look like it is ...
Darren
Proven Zealot
Status changed to: Declined
