When you want to change cluster properties, you will have to right click on the frame of the cluster. For me it´s really a challenge to hit the right area to get into the right menue.
My suggestion is to make the area bigger, where you right click on...
Example:
right area hit:
wrong menue, which I hit more often than the right one:
