6 | |
6 | |
3 | |
2 | |
2 |
Currently (in LabVIEW 2010), you can add labels to wires. Hurray!!
But it's painful. Boooo!
Curently => Right-Click wire, navigate to sub-menu of Show>>Label
It should be as easy as adding free text to block diagrams or front panels. For example: If your auto-tool is on then just double-click on freespace to add text.
So we should make it just as easy to add labels to wires:
Re-opening because LabVIEW NXG has been discontinued.
