13 | |
11 | |
3 | |
3 | |
2 |
I would suggest that NI makes the datatypes of the "Quotient and Remainder" VI consistent.
If you now wire a double to the VI the outputs are of the datatype "double" however in my opinion this is not consistent with the mathematical definition of quotient, floor(x/y) and remainder, x-y*floor(x/y). The output of the VI is always a integer and should therefore also be of that datatype, thus one of the following datatypes (I64, I32, I16, I8).
