10 | |
3 | |
2 | |
2 | |
2 |
My idea is simple... It could be helpful to add automatically a connection (input/output) when we draw a wire through a flat sequence. At the moment, we have to connect the wire on the left side and than, passing through the flat sequence to the right side...
