When setting developing an application that uses a Modal pop-up window it can be very frustrating when the pop-up appears on the monitor you are not looking at.
In the VI properties you can choose the position and you can choose which monitor to use as seen in the attached .png.
It would be great if we had an option to choose "application montior" so the Modal window would appear where ever your VI or exe is running.
