| User | Kudos |
| 12 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
When I insert a VI into the error wire, I almost always want to insert something from the same palette as the VI that precedes the one being inserted. For example, I usually want to insert a close or release function that is related to the previous VI. Unfortunately the options presented are not very useful since they only offer up the Dialog & User Interface Palette, the Cluster, Class & Variant Palette and the All Palettes. Why not include a shortcut to the Queue Operations Palette if the preceding VI is a Queue VI from that palette?
This seems like an easy one to implement and will speed programming for those of us who still like to use the right click palette menus to program.
-John
Any idea that has received less than 9 kudos within 9 years after posting will be automatically declined.
