When you have something to print you can develop a VI with the option : 'print after execution'
With complex information, you can have a printable VI for graphical data, a VI for array data, ...
When you print all data you have a lot of paper.
But when your printer is a PDF printer, you have a lot of file with 1 page and not 1 file with a lot of page !
I suggest to have a way to create a print task, add a VI to print (with a option like 'add to print task after execution') and to have a command for run the print.
Advanced option :
A option to create more a print task.
So you can prepare the print task and juste run it on a event (and no loose time to build or re build the data if the same event comes again).
Regard's
EricC
