8 | |
3 | |
3 | |
2 | |
2 |
I just downloaded a library and a project it was developed in. I tested it, and everything works fine. Then I copied the library (.lvlib, all .vi files and preserving folder structure) to a new project, but when I open it I get a conflict saying that the same library is defined twice? A conflict that cannot be resolved BTW.
I spent 30 minutes just getting out of the mess this puts me in. The result, project2 is now OK, but project1 now complains that it has duplicate code. Come on! I know I have two copies of the same library! I want to have two copies of the same library! Why can't LabView just use the "local" version and not complicate my life with something that happens to lie on the disk somewhere and has absolutely no connection to the current project?
