For some days i had to create multiple CRio targets in my LabVIEW project, using the same Labview Code.
( I wanted to test my application on different CRio versions, in order to check CPU usage)
I first try to use the contextual menu to find out the available commands on targets, CRio backplane, and FPGA target.
=> I don't find any command to easily duplicate my target. ![]()
=> So, i had to create a new target, completly, step by step ![]()
(Create a new Crio target, a new backplane, a new FPGA target ... new FPGA FIFOs, new FPGA C series modules .... .)
Yesterday, i talk with our NI commercial about this problem, and he says ... you have only to copy and paste the items of your project.
=> This work fine ! ![]()
It should be nice to made the copy/paste command (and perhaps other commands) available in the project treeview context menu.
All available commands on items should appear in the treeview context menu, in order to guide the LabVIEW users.
Thanks.
Manu.net
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
