6 | |
6 | |
3 | |
2 | |
2 |
Hi
A recent discussion on the forum "why not everybody uses units" explains this much better than I can.
But for faster readers, several bugs hinder the universal use of units in LabVIEW.
It is a wonderful system but should be completed in a way (at least the square function should be using it) but all the other remarks found in that thread like the identical look of the expression node and the unit, not working formula nodes etc. should at least be taken seriously.
I lik the system but for now it is hindered by too many bugs.
