6 | |
6 | |
3 | |
2 | |
2 |
I've been programming in LabVIEW for a decade. Yet, there is still an issue with type def'ing a cluster. If one of the goals of LabVIEW programming is documentation, why does NI still make it the process difficult?
After creating then 'type def' a cluster, I then have to more spend time unhiding and repositioning labels. This gets extremely inefficient with large cluster.
Why not add an option to hide or leave labels untouched when 'type def'ing a cluster?
