2 | |
2 | |
2 | |
2 | |
1 |
I couldn't find this explicitly mentioned here, but it seems related to:
Block diagram references should be 16 pixels tall (currently 19 pixels) - NI Community
Same Height of Unbundle by Name / Terminal / Local Variable - NI Community
Although making changes like this could hurt legacy code, earlier implementation is preferable. Local variables are already the same size as bundles and property nodes, but constants are not. My suggestion is to increase the size of bundle/unbundle elements by one pixel and decrease the size of constants by two pixels by reducing their border thickness. Since numerics require a type indicator, a 1 px border wouldn't compromise recognition. Numeric constant type visualization - NI Community
