_carl
Mechanism for Accessing DVR Data from Control/Indicator/Wire
Status: New
I often work with DVRs, usually using typdefs or classes for the underlying data.
It's a serious pain to access the typdef or class from the DVR itself (control, indicator, or wire).  There's no option for accessing this through the menu, and I often find myself dropping code in my block diagram to output the data type, then right-clicking on the data type and then from that menu opening the typdef or class.
The request: add a menu option for "Open Data Type Def." or "Show Data Class Library" to directly access the underlying type if it's a type def or class. This menu option could be exposed on wires, controls, and indicators.
3 Comments
crossrulz
Knight of NI
In the mean time, you can right-click on the DVR ref and choose "Show Control".  From there, you can access the data type.
_carl
Woah... crossrulz....you deserve more kudos than the 1 I'm able to give you!
I had no idea that feature existed.  And I've been working with DVRs for a while.  That...is...well, short of life-changing, but... will safe future me hours of annoyance!
wiebe@CARYA
Knight of NI
If you still find you want that menu item, you can make your own shortcut menu plugin:
LabVIEW Shortcut Menu Plug-Ins - NI Community
Note that crossrulz's trick also works for queues, notifiers and user events.
