 code-lux
			 on
		01-10-2023
		09:06 AM
			3 Comments (3 New)
			code-lux
			 on
		01-10-2023
		09:06 AM
			3 Comments (3 New)
		When hovering over Typedef / Custom Control (*.ctl) in the Project Manager, the Context Help only shows the Icon and ev. a custom VI Description.
It would be very helpful if the Information and the wire pane image of the contained Control was also shown in the Context Help of the Typedef.
This improvement would reduce the needed effort to write VI Description or avoid opening several Typedefs until the right one is found.
