| User | Kudos |
| 4 | |
| 3 | |
| 3 | |
| 3 | |
| 2 |
In LabVIEW project file XML some information are generated by LabVIEW. For example:
These information should not be commited to source code control system and having them within the LabVIEW project file makes it very painful to maintain a clean GIT history.
It could be very convenient to store these information into a separated file with a specific file extension so that we can easily ignore with .gitignore file.
