| User | Kudos |
| 11 | |
| 10 | |
| 6 | |
| 5 | |
| 4 |
On a Mixed Signal Graph with two plot areas, dragging the splitter that is located between the two plot areas changes the absolute height of the top plot area while keeping the height of the bottom plot area constant. So if the splitter is dragged down to increase the top plot area height, the bottom plot area scrolls down off the graph and a vertical scrollbar appears. I wish to keep the total sum height of all the plots constant and instead have the relative ratio of the two plot areas change when the splitter is dragged, i.e. the scrollbar would not appear and the bottom of the lower plot area would remain fixed at the bottom of the graph. This behavior would be general for multiple plots.
