6 | |
6 | |
3 | |
2 | |
2 |
I work as a LabVIEW integrator and for one of my customer I develop application, with maintenance goal for their installation all over the world with RS232 or Bluetooth communication for example, deployed on targets as PDA (PocketPC 2003 & Windows Mobile 6) or Touch Panel (Windows CE 4.2 to 5.0) using LabVIEW 8.6 Mobile Module.
This LabVIEW additonal module works quite well to deploy the same application in this differant targets, but I encountered some problems and I have some suggestions for Mobile Module :
1/ MMI (Man Machine Interface)
- for graphics indicators (as Gauge or Slide) graphical object ramp or multi Slider is deleted by LabVIEW when you build an EXE => I think that a graphical objets with all its graphical property could be added in Mobile Module (and works on these all targets). See examples in GraphicalObjects.PNG
- as I say in my introduction my application is deployed all over the world and usually I used "Caption" dynamic modification for multilingual management for all my controls & indicators. But in mobile module we can't do this (but we can modify dynamically boolean text), so I think that it could be possible.
2/ VISA (& Bluetooth) Management
- I think there is a bug with VISA installation. Indeed with the installer you can choose the installation directory (default directory or specific directory : in non volatil memory) but if you don't install VISA support in default directory it doesn't work (with PocketPC 2003 for example) I think that could be resolved
- As I said in introduction my application could communicate throught different protocols (RS232, Bluetooth) and with LV 8.6 Mobile Module we can now use VISA : great !!!. But in Windows Mobile 6, VISA does not support bluetooth (it seems to have an incompatibility with virtual aliases in the registry) ; and in PocketPC2003 it works very well. I think that could be resolved
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
