8 | |
6 | |
4 | |
3 | |
2 |
Currently if you would like to update the properties of multiples of the same item (e.g. Variables, indicators, controls, etc.) you must update the properties individually. I would like to see the feature added that would allow me to update the same property on multiple items at the same time. For example, if I'd like to set 10 shared variables to "write" or change 15 indicators to controls, I would like to be able to highlight them all, right click on one, and then have the change applied to all of the selected items.
