Bob_Schor
More consistent Chart History
Status: Declined
I have an application where multiple clones "feed" data to an Executive routine that includes a (scrolling) chart displaying the data points (10 Hz) from one of the selected clones.  The Executive gets its points from a queue, and the Chosen Clone puts its points into the queue.  Since I want to see "all of the data", each Clone maintains a "history" in the form of a Lossy Queue (very similar to the ring buffer inside the Chart -- it "remembers" N points then starts overwriting).
To make this work properly, I need to (at Run Time) create my Clone "History Queue" to be the same size as the History buffer of the Chart.  But there's a problem -- there is no way to set the size of the Chart buffer at Run Time (I do realize this is because the buffer is allocated at compile time, but if we can allocate a lossy queue at run time, why can't a similar technology be used to allocate the buffer for a chart at run time?).  So you need to right-click the chart and manually set it.  OK, so at run time, we can use the History Size property to allocate our Lossy Queue to be the same size.  Except there no History Size property.  There is a History property that returns the History, but if it's a new chart, the History is empty, so the size returned is zero!  So how do you figure out its size?  [I worked out a method -- simply put "junk" (anything) into the chart, retrieve the History at each step, and stop when the History stops growing.  But what an awkward kludge, not to mention a time-waster ...].
I'd like to propose two (ideally) changes to Charts.  First, figure out a way to allow users to programmatically set (or change) the size of the Chart History.  Should this really not be practical, at least provide a Property (read-only) to return the size manually set into the Chart.
Thanks for your consideration.
2 Comments
tst
Knight of NI Knight of NI
Knight of NI
My suggestion - if you're already keeping all the data yourself, just keep the X data as well and use a graph instead of a chart. An added side benefit is that now you can have points where the X step is not equal. You can see the data type for the graph if you open a context help window and hover over its terminal. There should also be a shipping example showing the various data types.
___________________
Try to take over the world!
Darren
Proven Zealot
Status changed to: Declined
