I often have to duplicate a system, and it is hard to find and install the exact same driver versions.
If I download the drivers separately I often end up with many large files since much content is added to all drivers.
I would be nice if I could configure a list of required drivers (with specific versions) through a web page, and then download a single installer file containing just the selected drivers.
