6 | |
5 | |
2 | |
2 | |
2 |
When we open and not making any changes we close the code refering to the API of components which version differs from the version was used to write the code we are getting the standard message do we want ro save or deffer the changes or cancel the operation.
When we hit the buton/link 'Explain the changes' as the result we are getting the 'not explaining a lot' message: 'External component has been changed'.
It would be very practical to have the information what exacly has been changed.
