A customer of mine want to create multilingual applications. They are sloving this right now by im- and exporting strings. They found a tool in the Internet, that can extract texts which can then be processed and be imported again. The VI has then to be saved and compiled, which is very time consuming.
He programmed a tool for a Windows Applications which is working similar. In that tool it is then possible to change the language. But we would need some soft of language lists.
His Idea to slove it easily is to implement subtitles (maybe around 5) in every forntpanelelement in which you could set the translation similar to a button text. The same way could be applied for the tips and the description. These Subtitles should then be switchable during the test to get the proper language version.
