| User | Kudos |
| 9 | |
| 9 | |
| 4 | |
| 4 | |
| 3 |
I would like to have multiple windows for the same VI available for LabVIEW. One example of this is in onenote. If you hit 'control M', another window pop's up and you can edit, drag and drop, etc, both tied to the core file. This would be useful for debugging, coping code to a different case, etc.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
