13 | |
7 | |
4 | |
2 | |
2 |
It seems there are a lot of NI services that start running directly after logging in to windows. I even tried manually turning them off using msconfig thinking the services would start when LabView was loaded or on an 'as needed' basis, but I was wrong.
The user should have the option of starting services at windows startup or at LabView startup, or even not at all if it is not required. Perhaps this could be added to select the services within LabView's 'Options' menu. An explanation of each service and why it is needed would be great also. With all of the programs that run on our computers these days, the less running in the background, the better.
