13 | |
7 | |
3 | |
3 | |
3 |
Currently, the TDMS File api does not offer a way to get the TDMS file size.
Our use case is that we'd like to limit the size of the TDMS files and span them accross multiple individual files (and I've posted an idea suggestion for adding that as a native feature, too). To do this, we need to be able to monitor the TDMS file size, so that we can save/close the current file and then create the next file in the span for continued use (until we hit the size limit again).
