13 | |
7 | |
3 | |
3 | |
3 |
Background
The DAQmx apis allow streaming measurements to TDMS. This supports spanning multiple files (by setting the max file size for individual files in the span set), which is very useful.
We need a similar feature for files we're writing to directly (i.e. not using DAQmx) with the TDMS File functions in LabVIEW.
Note: The main reason we wanting this feature, right now, is that our files are growing quite large and when we run the TDMS Defragement function, we get out of memory errors in RT on cRIO (e.g. if we have 512MB RAM on our cRIO and the TDMS file is around the same size).
Alternatives
We're thinking to do this ourselves, however the TDMS file api does not support checking the file size from a TDMS file reference (and that's a great idea, too).
I'm not totally sure how this would be added to the TDMS file api -- maybe there could be a "TDMS Advanced Spanning" palette with options for configuring and interacting with TDMS spanning.
