| User | Kudos |
| 8 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
INTRODUCTION
Dealing with arrays that are passed by reference (using control RefNums) to a SubVI has much more utility if it is NOT necessary to extract a local copy of the array in order to play with it. In additiion, there are some properties missing from arrays and clusters that would make it much easier to write code, and which seem to be consistent with other objects' property offerings.
Note: All proposed properties are IN ADDITION to existing properties. The behavior of existing properties is NOT changed.
NEW PROPERTIES
The following is a list of the proposed new properties:
NEW ARRAY PROPERTIES
ArraySize
ElemIndex
ElemRef
ElemRefs[]
NEW CLUSTER PROPERTIES
ControlLabels[]
DISCUSSION
Array Sizing
CURRENT: If you pass an array reference to a SubVI and want to know the size of the array, you need the wire the array "Value" property to the reference (which allocates space
and creates a local copy of the array) so that you can then wire the array to ArraySize to find the number of elements in the array.
PROPOSED: I propose a new array property "ArraySize" to return the number of elements in the array. This would have identical functionality as ArraySize.vi, but would be implemented
as a property where it can be used with array RefNums.
Deriving References to Array Elements
CURRENT: If you want to traverse an array and generate a list of references to all elements in the array, you have to first set the "NumCols" and "NumRows" to 1, and then use IndexVals
(to set which element is indexed) followed by "ArrElem" to actually get the reference.
PROPOSED: It'd be a lot sweeter if two more properties were added to arrays; the first would (obviously!) be an index function that is NOT related to the visibility properties of the array (as is
"IndexVals"). Let's call this new property "ElemIndex". Of course, in order not to break existing code, you cannot let the "ElemIndex" property cause damage to programs that currently
use "IndexVals", so we also need a new property (let's call this one "ElemRef") that returns the reference to the element in place of "ArrElem".
Obtaining References to Multiple Array Elements
CURRENT: Currently the "ArrElem" property returns a reference to a single element. it would be nice to get an array of references to elements in an array in the same manner as you can get
an array of references to all controls in a cluster using the cluster "Controls[]" property.
PROPOSED: So let's create another array property called "ElemRefs[]" that returns an array containing a reference to each element in the array.
Identifying Cluster Members Obtained Using "Controls[]"
CURRENT: The "Controls[]" property of clusters suffers from the problem that you have to know the order of elements in the cluster if you are looking for a specific cluster member. If you write
code using "Controls[]" then you are dependent on the order of elements in the cluster. When the cluster is a strictly typed control, this defeats the advantages of strict typing. The
effect is that when you change the type definition of a strictly typed cluster so that either (1) the order of elements change, or (2) you insert or delete an element, you have to rewrite
code that used the "Controls[]" property if that code needed to identify specific cluster elements and not just process all elements identically.
PROPOSED: A new property, "ControlLabels[]", alleviates this problem and adds significant utility to clusters, especially those strictly typed. The ControlLabels[] property when added to clusters
allows the references returned by the "Controls[]" property to be matched to a specific cluster element using that cluster element's label. The ControlLabels[] array returned would
be the labels of all cluster elements in the same order as the references returned by the "Controls[]" property (which is in the same order you see with "Reorder Controls in Cluster") .
This means that code written for a type defined cluster will still work if the type definition is modified either in the order of controls in the cluster, or if new elements are added or deleted
(so long as the deleted element wasn't one that was handled specifically in the code!).
