I can use CTRL-drag to insert space into a labview diagram.
I want to be able to ALT-drag to remove space from the diagram.
It should use the same type of logic as when you grab the handle on a structure (case statement, flat sequence, etc.) and should 'bump up' against any objects (hidden or not) and stop. The only objects that are allowable in the region being removed would be wires; and the requirement would be that they have an in-and-out format such that the deleted area is consistent after removal.
This would be SO useful...
