JackDunaway
New Run-Time Window Postion Option: Center on Caller
Status: New
The current method I use for centering a subVI called from a caller ("parent") VI is rather involved:
Instead, a new property should be introduced to the Run-Time Position under VI properties:
The shortcoming of not being able to have a subVI popup center on the parent is something that has bugged me in the past, and I was inspired by lvABC's idea to create this broader idea that would apply to all subVI's.
12 Comments
Ben_Phillips
Brilliant simple solution.
_carl
It's been a decade, would still like to see this feature!
