11 | |
11 | |
3 | |
3 | |
2 |
Hi
Is it possible that the contents within the instr.lib to be defaulted to read-only every time LabVIEW launches? VIs that is drag-drop from the pallet onto block diagram is currently modifiable and may cause unintentional code modifications, especially due to the 'save all' function and hasty/improper shutdown. The extend of the damage may be inherited over time.
Also propose to default modified instr.lib VIs saves to be in active project folder instead of the instr.lib.
Hope to see these features in future versions.
