8 | |
6 | |
4 | |
3 | |
2 |
If I create an application and start it for the first time, an ini file is created with default values, which at least I d'ont know, where these default values come from. There should be a transparent method to configure the default ini options of an application. I think a new page in the application builder, which provides all possible ini parameters, is the way to go.
With this new feature I can shsre my exe without the ini file, too.
