11 | |
8 | |
3 | |
3 | |
2 |
If you write a multi-purpose sub-VI, it is sometimes desirable to know during run-time, if an input of the sub-VI is connected to some source inside the calling VI or not. E.g. if you have two inputs and you want to do a certain action whichs depends on which input is connected, you have to write a polymorphic VI. Therefore you have to write at least 3 VIs: one VI for each input and the polymorphic VI. With a new control property or method, which tells you if the input got it's data from some source, you could do this with just one VI. There are of course other scenarios where this new feature could be useful.
Marc
