7 | |
6 | |
2 | |
2 | |
2 |
I'd like a comparison block to tell us if a timestamp is a valid one or not.
By not valid i mean showing something like "DD/MM/YYYY" instead of mumbers, as a newly placed timestamp control does.
You can't just check "= 0" because actually an invalid timestamp could also be a NaN or any large positive/negative number!
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
