We do Create Constant/Control/Indicator a lot when working on a block diagram. It could be much easier. How about the following:
Double-click on output terminal with wiring tool - Create Indicator.
Double-click on input terminal with wiring tool - Create Control.
Ctrl-click on input or output terminal with wiring tool - Create Constant.
Front Panel Control/Indicator
Ctrl-click on node should Create Property Node.
Ctrl-double click should Create Invoke Node.
National Instruments will not be implementing this idea. In LabVIEW 2019 and later, the 'Create' menu options for terminals are always available at the top of the right-click menu, making them much more efficient to select.
