6 | |
5 | |
2 | |
2 | |
2 |
Many modules aren't compatible with Labview 2010 64 bit, but there is no warning of that before installing Labview 2010 64 bit. So the user goes through hour(s) to install the software, only to realize it won't work when he/she installs a module (Real Time Module for example), and then has to uninstall and reinstall the 32 bit version. If it isn't compatible, let people know so they don't waste hours!
