8 | |
6 | |
5 | |
4 | |
4 |
The Event Structure is able to catch the information when Windows is shutting down is the event "Application Instance Close?".
That event don't work in Linux OS. It exist a workaround in Linux with CIN code, but since CIN has been deprecated with LV 2011, the is no actual workaround.
http://digital.ni.com/public.nsf/allkb/C2470DFFFC71D47F86256F70005891C6?OpenDocument
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
