I know this sounds like a minuscule feature request, but this is an option I have learned to appreciate in Origin (and one of the reason I usually go through that software for publication-quality plots).
Just in case what I am suggesting is not clear, here is an example of a graph scale using the Scientific style:
The suggestion is about changing 1E+0 to just 1.
And this can even be an option (as it is in Origin) if some minds out there think that 1 is not a peculiar value and it would break the uniformity of the display or whatever other reason.
Obviously, if you have chosen a precision of 1 (or 2, etc), 1.0E+0 would be replaced by 1.0, etc.
