7 | |
6 | |
2 | |
2 | |
2 |
Let's say I have a class with a few public VIs, and several private VIs and typedefs:
Assuming I'm not working on a VI within the class, If I'm using this class on a block diagram, I can only use the public VIs.
However, if I right-click on the class wire, and go to the auto-generated class palette, it shows everything. This can be absolutely overwhelming with larger classes. Why not scope this palette appropriately?
