6 | |
6 | |
3 | |
2 | |
2 |
Many analysis VIs make use of strictly typed model functions and NI provides templates that are mentioned in the help for the function. When writing an analysis program using any of these tools, the clumsy part is getting the template. Since the path listed in the help is relative to the LabVIEW folder, it cannot be pasted directly and requires deep and tedious folder navigation.
As an example, here's how the relevant part of the help looks like for nonlinear curve fit. The yellow part outlines the model.
The LabVIEW help already has mechanisms in place to open examples or place function on block diagram, so I don't really see why opening a model templates requires jumping through flaming hoops.
IDEA: I suggest a little button or link on the relevant help page that allows opening of the associated template with one click.
Here's a list of templates found in the gmath hierarchy. The help pages of all their "mother VIs" need to get updated according to this idea.
