13 | |
11 | |
3 | |
3 | |
3 |
Using the LabVIEW 2009 Build Spec (as an example) allows you to add a Destination to a Library which is very handy, as it means you can namespace VIs at build-time.
I would like to take this a step forward and then be able to set that new Library as a Sub-Library of another Library that already exists in the Project.
I would then want to be able to set the scope of this Sub-Library as well (relative to its now, Parent).
This combined with my Locking State Idea would allow be create a Distribution that would hide and protect a Support VI Library
As the Sub-Library would be Private Scoped (from above) and the Parent Library would be set Locked (does not show Private Members).
I currently can implement this using Scripting but it would be nice to have it native.
Cheers
-JG
