Darin.K
Option to De-"Expressify" Express VIs
Status: Declined
Functionality already in LabVIEW
In moderation I find that certain Express VIs are quite useful, in particular Elapsed Time, Time Delay, File Dialog, and Prompt User, but I really dislike the default behavior.  I would like to choose when I go to the configuration page, and I never use the default view.
So, to make these things a bit more palatable (palette-able), I would prefer a setting (INI key or Environment Option) to De-Expressify the Express VIs, meaning that they drop silently to icon view like any other subVI.  You can still double-click for the config page when desired, for the ones I use I rarely need to configure anything.
It just makes them fit a little better into the normal workflow for the non-newbie users.  Right now I have palette items which do nothing but drop iconified Express VIs.
10 Comments
tst
Knight of NI Knight of NI
Knight of NI
Maybe I'm misunderstanding what you want, but there should already be an option for not showing the config dialog when dropping the VI. It's probably in the BD page of the options dialog.
Also, I'm not sure, but I think there's also an option for dropping them as icons and not as expanded. Presumably it would be in the same place.
___________________
Try to take over the world!
Darin.K
Trusted Enthusiast
Well I hope you are right, I looked a long time ago but could not find the options and went the palette route. I bow to your superior knowledge of Express VIs. 🙂
crossrulz
Knight of NI
If you go Options, Block Diagram, there is a "Configure Express VIs immediately" option (at least as of 8.6)
Darin.K
Trusted Enthusiast
For some reason I expected an Express subsection, indeed in the General BD options I can ditch the configuration.  Smiley Happy
Stuck with non-icon view apparently.  Smiley Sad
AristosQueue (NI)
NI Employee (retired)
Pop up on the subVI and choose "View as Icon". That option is available on all subVIs, but it defaults to false for Express VIs.
Darin.K
Trusted Enthusiast
Allow me to rephrase "Stuck with changing all of them from non-icon view Smiley Mad "
Would have been hard to create my custom palette items which drop as Icon View had I not known about that Right-click menu item...
tst
Knight of NI
There is a Place subVIs as expandable check box, which is (unhelpfully, in this case, near the show terminals as icons check box and is) probably what I was thinking of, but the help for it says it doesn't affect express VIs.
___________________
G-Money
Status changed to: Declined
G-Money
This functionality is available in LabVIEW versions 7.0 and later.
Darin.K
Trusted Enthusiast
For the record, my idea is to have the option to drop the ExVIs directly as icons, without the need to right-click. This is certainly NOT in LV7 or later. May not happen for many reasons, I just do not buy that one.
