Often it is desirable to know if a control on the connector pane was wired or not. At present this can only be done by checking the value or by making the control a variant and checking if an error occurs when converting it to the proper type. Both of these have issues. Using the default value does not always work because you may need to take different action it is is truly not wired. If the control is an ENUM it would mean you have to include some value like "Invalid" in the list. This can cause confusion when using ENUM constants because it would appear that the ENUM has another value. The variant approach is problematic because it defeats automatic type checking by the compiler. It would be best if we had a simple property node on the control to indicate if it is wired or not.
