When reviewing old projects or VIs, the "VI changed" title bar star is always only a few mouse clicks away. And beware of accidentally opening an old project with a newer LabVIEW version!
You all know the "vi has unsaved changes" dialogs that follow when just wanting to close the windows, and who has not at least a dozen times saved an old VI in one of these situations just out of a misplaced click or the habit to save your code whenever you you are prompted to...
This is why I propose a new file menu entry: open (locked)... or open (read-only)... or an "open options" control in the file dialog.
Its functionality would be to open the selected file or project in a similar way like the locked VIs: you can look at them, browse through case or event structures, but cannot change a thing...
Even better would be the option to allow changes (e. g. move/delete some portions before selecting the rest for copy&paste), but to prevent re-saving the file under the same name. For this case, trying <CTRL-S> or closing the file would open a dialog stating that the VI was opened as "read-only" and that you may either discard the changes or save the file under a new name.
Of course, this "read-only" flag would be inherited to all subVIs, typedefs etcetera that would be opened from the original project or VI.
And to make my whishlist complete, a color coding of the VI window / project frames would signalize the read-only state of the code:
By the way: Wouldn't it be nice if VIs in vi.lib featured this opening mode by default?
Sebastian
